problem creating asf file
Gary Puckett
Company Name: The Woodworkery
Post by Gary Puckett »
I am getting an error when I try to create a hsf file. Does anyone have a clue on why this is now happening?
Re: problem creating asf file
Gary,
Need more info. What are you trying to convert and where, Post the offending file. Try rebooting eCabs and Windows.
Gary Puckett
Kerry,
I was going to make fluted trim and post it for a new member. I made the piece in the cabinet editor took it to the part editor, put the flutes in the part returned to the cabinet editor and went to turn it into a HSF. Thats when I started getting errors and it would not convert.
Gary,
Is this a Display Board, Display Panel or Display cube?
Did you export the part to the Display Part Editor and save it there or is it a cabinet face frame part?
Gary Puckett
Kerry,
I tried all display board, display panel, display cube, I get the error every time. I can not export the part, I get that error I posted. I restarted windows and eCab. and I still get the error. The Part is just flate stock 6" wide X 96" long with flutes in it.
I am trying to export this part in the cabinet editor.
Doesn't it have to be a cabinet part to be saved as a hsf file? A display part saves as an esa file.
Gary Puckett
Re: problem creating hsf file
Rick,
I even tried to export the standard toe kick and I still got the error.
Try using a Back.
Gary Puckett
Rick,
I got the error even using a back.
:evil: VISTA :twisted:
Gary Puckett
Kerry,
I am sure I was able to do this in the past and I had Vista. PLEASE HURRY WITH V6
Daniel Vonderheide
Post by Daniel Vonderheide »
Gary,
Can you tell me exactly what you are doing step by step? I would like to reproduce this and make sure it is not an issue in version 6
Gary Puckett
Daniel,
I am creating a display board 6" wide X 96" long, taking it to the display part editor putting flutes in it, returning the part back to the part editor, highlite the part chose export to create HSF file. Chose to put the file on my desk top, name the file flutes hit save and I get the error.
I can do the same thing with the standard toe kick and I still get the error.
I've never used that function before. It works for me. I was able to save to desktop and open the part it the Display Part Editor.
Gary Puckett
Gary Puckett wrote:Daniel,
Sorry I meant returning to the cabinet editor not the part editor
