I have a job that I have been working on that now when I try to open I get the Error (An error occurred while loading HOOPS information from the saved file)
and then (there was an error after opening the job file)
Has anyone ever found a way out of this problem?
This has happened many times to others, if the file can't be retreived did you save the cabinets? If you did then just redraw the room. In the future as you move forward on a job start saving and each time you save rename the job for example Jones Job 1, Jones Job 2, and so on . That way if the last file you save some how messes up you can pull up the file before.
