Door on Wall Cabinet
Gary Puckett
Company Name: The Woodworkery
Post by Gary Puckett »
If anyone will still talk to me :joker: How do you put a door on a frameless wall cabinet with a slant front? The front of the sides are 45 degrees to the front of the slant face.
wall cab.jpg (71.81 KiB) Viewed 24260 times
Jon Kenworthy
Company Name: darrells Carpenter Shop
Re: Door on Wall Cabinet
Post by Jon Kenworthy »
We use CAD software to determine the size of the door needed then set the hinge side and open side reveals so the door is the correct size. We normally use the hinge mount holes but I haven't been able to figure out how to get these to end up at the correct location so for this type of cabinet we use a jig to place the hinge mount holes after the cabinet is put together. We use the Blum 45 deg angle hinges which sets the door out from the cabinet so the from the front you have the correct reveal to the next door, then on the open side we use a thicker bumper than normal to get approximately the same spacing from the cabinet to the back of the door. I attached a couple of pictures to show the process we go through.
Drawing for Corner Cabinet.JPG (13.16 KiB) Viewed 24247 times
Angle Front Cabinet Top View.jpg (21.61 KiB) Viewed 24247 times
Wally Schneeberger
Post by Wally Schneeberger »
Gary Puckett wrote:If anyone will still talk to me :joker: How do you put a door on a frameless wall cabinet with a slant front? The front of the sides are 45 degrees to the front of the slant face.
If this is a 24" x 24" corner cab x 12" deep -- I find that a 16" door gives the clearances needed to butt to the next cab and still open. You can set your reveals to make this happen.
Gary Puckett
Thanks Guys,
I have no experience with a frameless corner cabinet. I have no idea on how to draw this so I will just show it as a corner open shelf unit.
Darren Harvey
Post by Darren Harvey »
gary here is a couple of wall corner cabinets we've done. i forget the specification but look around. hope it helps some what. darren
wall corner L.hsf
(290.02 KiB) Downloaded 1650 times
wall corner R.hsf
(270.02 KiB) Downloaded 1704 times
Gary Puckett
Thanks Darren,
I will take a look.
Joe Harkin
Post by Joe Harkin »
Darren, do you have the jpeg's to go with those hsf files ?
Darren Harvey
joe, here are the jpegs. darren
wall corner R.jpg (11.29 KiB) Viewed 24212 times
wall corner L.jpg (12.51 KiB) Viewed 24212 times
