iam trying to do a simple job with 2 pockets of 7.5mmwide and 1150mm long through cut gives me error failed to create toolpath for the pocket operation
what is that missing in my settings,its fine with other jobs pls help
pocketing in CN 5.50
mohan kommineni
- Country: AUSTRALIA
- lane panels.twd.esj
- cnc file
- (114 KiB) Downloaded 306 times
- lane panels.esj
- design file
- (94.02 KiB) Downloaded 314 times
- ControlNest5-50.cab.esj
- machine settings
- (88.07 KiB) Downloaded 318 times
Ryan Hochgesang
Re: pocketing in CN 5.50
Mohan,
I have downloaded your files and will take a look and get back to you.
Ryan Hochgesang
Mohan,
We've found an issue with Control Nesting 5.50 using the pocketing feature with your particular setup. We will get issue addressed as soon as possible and get fix in next update release. In order to cut this particular part, you can increase the Pocket Area (Through Cuts) to 8625 mm^2 and control nesting will then find the correct pocketing tool for operation. You can also setup tooling so that the specific pocket tool (T11) your wanting to cut pocket is only pocket tool in list.
mohan kommineni
thanks for that RYAN
i hope as you said this issue will be fixed in the next update release
ur suggestion has solved the issue for now
thanks
thanks
