Had my knickers in a twist. So I post this just in case other members have been having the same question. At first it looked like v6 no longer had the feature for changing all doors or dwrs, etc from Room view. It had disappeared from the drop down menu. It has just moved! When selecting a single cabinet, a button suddenly appears in the new Items Screen (two monitors has become a must have) that says "Cab. Features". Here you can make the changes. If you use the drop down menu from the Room screen to select All Base Cabinets or All Cabinets, etc., you DO NOT immediately see the "Cab Features" button appear. In this case you have to click on the part ("Door Drawers" , "Drawer Boxes", etc) that you want to change for the "Cab Features" button to appear.
Hope this helps.
ver6 Changing Cabinet Features from room View
James Melvin
- Ryan Callahan
Re: ver6 Changing Cabinet Features from room View
James,
The Cabinet Features now shows as soon as any cabinet is selected. This should eliminate confusion in the future.
Ryan Callahan
Thermwood
Thermwood
- Josh Rayburn
Hi Ryan,
Will the issue for assemblies be fixed in the next release? Can't remember the post, but the 'cab features' button will not appear for assemblies in a room.
- Ryan Callahan
Josh,
How was this not noticed already.
OK, I am making this a hot issue and it will be fixed in the next release.
As a work around, if you select a std base fless in the room with an assembly, then you can adjust assembly features. Just be sure to delete your sacrificial std base.
Thanks for the catch.
Ryan Callahan
Thermwood
Thermwood
- Kerry Fullington
Hey Ryan,
This was noticed back in Beta Testing, it just isn't fixed yet.
