What does this mean? I modified a cabinet in V6 and it looks correct. When I try to save it I get this error message.
An error occured while adding hoops information to save the file. It wil not save my cabinet.
It let me save it as an assembly, but it is NOT an assembly
I tried to attach it, but all I can find are the v5 files to attach. The new files are there when the program is open, but they are not there when I go to
Program files/thermwood/ecabs/cabinets....ect Where are they?
ok, I found the files in a different location than I was used to.
Here is the cabinet that gave the trouble. This cabinet saved fine as is. I changed it to a 28 inches wide, 10 inch left stile on the face frame to make it like a blind cabinet, took off the drawers on the bottom and the center rail there, added a shelf and a door on the bottom.
Then I can't save it as a cabinet anymore. Only as an assembly.
It is not the string of where I try to save it, because I use the same string for other cabients in the same directory.
The error doesn't have anything to do with importing issues. It's a save location issue. It keeps happening to me too. You need to reselect your save location when you try to save the cabinet. It's extremely annoying because it keeps loosing it. There has been an issue with it in beta that I suppose was not resolved completely.
