V6 Build2
V6 Build2
I noticed that build 2 was attached the the full version 6 upgrade. After downloading I now need another Reg code, I expect I will need one for the laptop too. That is unless I missed something and do not need to upgrade to v6 again.
Lamar Horton
- Josh Rayburn
Re: V6 Build2
You should be able to re-enter the current reg code that you were using, it does not require a new one. Ryan may be able to give you the current code if you haven't got a record of it.
Hope that helps,
Hope that helps,
Re: V6 Build2
Me thinks there is still a bug in the LDE. I try and print to the printer and/or PDF writer and I get the Microsoft "Program has to close" box.
Lamar Horton
- Josh Rayburn
Re: V6 Build2
Still a couple bugs there, but I think they are Hoops issues, not Ecabs issues. 6build2 had brought some good tweaks, but the battle is not over.
I've brought lots of LDE issues up, and I know Ryan is working very hard on our behalf to get these issues fixed.
