I've started using the software, and everything seems to work fine until I try to edit a cabinet with a drawer on it. The program unfailingly shuts down when the status bar says that it is "Creating CNC Output" while "eCabinets is Processing the Drawer Box". Does anyone have an opinion as to whether this is due to insufficient system resources (I've listed my relavent system stats below) or a bug in the program? If it's the former, will increasing my RAM help? I appreciate any help on this matter, as I've reached a stopping point in my ability to follow along with the tutorials and am anxious to continue.
Karl Shikles
Karl's Custom Cabinets and Glass
OS - Windows Vista Home Premium
System Model - HP Pavilion dv5 Notebook PC
System Type - x64-based PC
Processor - Intel Core2Duo CPU T6400 @ 2.00 GHz
Ram - 4.00 GB
Available Ram - 1.38
Available Virtual Memory - 5,30
I figured as much. I'll try cleaning up my system and adding some ram before I invest in a desktop. Is there any way to stop the program from automatically generating cnc outputs since I (and probably most users) aren't using this program with CNC anyway? I haven't been able to find anything by searching the help index. Thanks again.
Even if you system is a little under powered, it should not be crashing when you regen a drawer box. What build of eCabinets are you using? Is there an error that pops up when it crashes? Can you get a screenshot of the error description in the event viewer?
My version is 6.0 build 3. I used windows' snipping tool to capture a screen shot. It always shuts down at this exact spot. Again, it seems to do everything else (nesting diagrams, rendering units and appliances without drawers, etc.) just fine. Let me know if there's any other info that I can provide. Thanks again for your time.
ecabinets error message.JPG (48.57 KiB) Viewed 7652 times
can you get me the error description from the event viewer.
To get to the Event Viewer go to Control Panel -> Administrative Tools -> Event Viewer. Click on Windows Logs->Applications and open the events that occurred when the installer popped up. Then post what you find for each event.
