I would like to slightly alter a hole pattern that is used in many of our library cabinets. After making the necessary changes to the hole pattern, do my cabinets using this hole pattern all automatically get updated once they are opened or used in a job or is there something I must do to get them updated ie- (open cabinet and regenerate?)
Thanks in advance.
Dale
Hardware hole pattern modifications?
- Dale Wills
- Company Name: none
- Country: AUSTRALIA
Rick Deskins
- Company Name: Thermwood
Re: Hardware hole pattern modifications?
Once you apply a holepattern, the pattern bodies are stored with the cabinet. If you want to change the pattern, even if it is the same filename, you will need to open the cabinet, reselect the new pattern file, and reapply to the cabinet (this will cause a regen to occur).
Rick Deskins
