I'm trying to add a double door to this corner cabinet and have specified a .0625 double door gap. The actual gap seems to be much more then .0625. Is this an optical allusion or when I order my doors, based on eCabs specifications, am I going to have a problem?
Double door gap problem.jpg (12.79 KiB) Viewed 2555 times
Don, if you take it to the LDE, and rotate it 270 degrees so your looking at the bottom, zoom in on the doors and press M to show the nodes the gap is indeed 1/16". It is the profile cut that is widening the gap. Maybe try a negative door gap and see if that will work.
