If you would happen to have a recent Export file saved somewhere you could get the latest OffFall.mdb file from it. But a delete is final and files can not be retrieved once deleted.
I had a brain fade....I had added a few off-falls to the list to use in a nest but then decided to remove some and thought the delete button I was using was to delete/remove only the off-falls I had added in to be nested but it deleted my complete off-falls library.
Dale
Just my opinion, but I think the "delete selected offfalls" and "delete all offfalls" buttons are not only too similar looking, but way too close to each other. I've almost done the same thing a few times. Perhaps a more ominous button, or one farther away would avoid this?
