I've attached a picture of a cabinet a customer wants. Is this possible using eCabs to do this with a cabinet and still have it cut properly on a CNC? I still would like to use BlindDado M&T joinery for the deck and mid shelf.
Thanks!
earlyamerican5-2 494x600.jpg (20.7 KiB) Viewed 22502 times
Sure
Use a deck float to shorten the face frame then inset the front of your deck. Cut the arc in the ends using the part editor and use a fixed shelf for the new deck at the face frame.
You have to do each side separately but when you do the first side, do it in contour and save the geometry. You can then open the geometry when you take the second side to contour and use it to make the cut. If you do this cabinet again you will already have the geometry.
Thank you, I will try that.
I saw in one of your posts, (WoodWeb I think) a render of a theater that you were checking "sight lines", did you do that in eCabs? if so, it was very well done
David
Thanks. Yes the theatre drawing was done using eCabinets. The walls were walls and most everything else is display cubes. The curtains are display cubes with a wavy part editor cut.
I apologize for the slow response. I was on a few night camping trip. It was my first time away from the shop in over a year. I needed the decompress
Thank you very much for the "how to" for this cabinet. I will be trying, for the first time, to use the contour editor to make sure the cabinet curves are symmetrical.
Take your left end into the part editor and then contour
Create your geometry for the cut in contour and save it to a file there.
Cut the geometry in the part editor and return the left end to the cabinet
When you bring the right end into the part editor use the drop down menu to choose C-Back view which flips the part
Now take the part into contour and open your saved geometry
This lets you cut using the same geometry without creating a mirror image of it
