print any one sheet
mark mcbride
print any one sheet
Post by mark mcbride »
i would like to know if im able to print out one sheet of a group of sheets. for example if i nest 20 parts over 5 sheets of plywood and i want to print out only sheet 3 of 5 is there an option for that?
thanks
mark
David Egnoski
Re: print any one sheet
Post by David Egnoski »
Mark,
In the pint dialog you can choose to print the selected sheet. When I tried it, the attached is what I got. No parts are shown for the sheet. Perhaps the Thermwood guys can check on this.
Dave Egnoski
Richmond Cabinet & Millwork
mark mcbride
thanks for the reply. i just tried it also and recieved the same sheet with no parts printed on it. i hope there is a fix for this.
JohnLashuay
Post by JohnLashuay »
Try writing the CNC file. Then in the upper section where it shows each sheet, double-click on the sheet you want and it should open up in a different window showing the parts and and itemized line listing.
-John
http://www.rylexonline.com
Thermwood CS 43
Mark,
Choose "Sheets" from the Print Setup drop down menu in the nest then click on File and Print
In the Print Dialog window that opens from Print Range select the Pages radio button then if you want to print page 5 enter from 5 to 5
It should then just print sheet 5
Daniel Vonderheide
Post by Daniel Vonderheide »
David Egnoski wrote:Mark,
Dave,
I have tested this and can confirm that any selected sheet besides sheet one prints blank. I will let the software engineers know.
Dave,
While you're at it, when you export the cut list to Excel, the sheet component worksheet has "Componet" instead of "Component" (note the missing n ) for the column heading.
David Egnoski
Thank you Daniel. I appreciate all that you guys, and gals, do for us.
Dave Egnoski
mark mcbride
thanks for the suggestions. im not seeing the drop down menus that were mentioned. i may have an older build then whats used in those suggestions. im sure the software engineers will get it all sorted out.
thanks again
mark
David Egnoski
Mark,
I think Kerry and John are talking about eCabinets nesting, not at the control.
Dave Egnoski
JohnLashuay
David,
I am talking about the control. Once the job is nested and you write the CNC file the layouts of each sheet come up at the top of the screen. Double click on the sheet and a new window comes up. You will see the sheet layout and also the line listing of each part. You can print from here.
-John
Printing Any Sheet.JPG (66.16 KiB) Viewed 17764 times
Thermwood CS 43
David Egnoski
John,
It looks like you are running a different version of the control software than I am. My screen looks nothing like yours.
Dave Egnoski
JohnLashuay
Hi David!
We just purchased our machine in December so I am not sure what the difference in software there is.
Maybe one of the Thermwood guys could chime in and shed some light on this?
Thermwood CS 43
Brad McIntosh
Company Name: CNC Automation
Post by Brad McIntosh »
Hello all...
John is running with the new QuickCut interface that is available on the recent THM controls.
You can read about it here: http://www.thermwood.com/header/quick_cut_main.htm
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
