Hi All,
I have a newbie question...I have developed a library of cabinets and generally all I wish to change is the finish for a particular customer.
I update my board stock and sheet stock image to the desired finish, but when I import the cabinet the doors do not change to the updated finish.
The face frames do change (after deselecting "common with door" on page two)
Am I missing a similar check box to have the doors change to the board stock I have chosen in "Define Materials"
Kevin
Door Color Matching Material definitions
Kevin Dunn
- Company Name: Castle Works
Wally Schneeberger
Re: Door Color Matching Material definitions
Kevin -- As far as I know you have to select all cabinets and change all doors and drawer fronts to the style and color that you want. When you do these changes you can save the job with a different name -- IE: Wilson job - color. The original saved job will still be there. HTH FWIW.
Kevin Dunn
HI Wally,
Thanks for the reply. So if I want to render the same kitchen in two different finishes for a client, do I need to go in and change the color on every cabinet, save them and then re-insert them in a room?
I am really new to the program so if I am overlooking something obvious just thump me on the head
Kevin
Kevin
Wally Schneeberger
No you can change all your cabs at once. You Right click for the menu and -- select all cabinets -- the -- change materials -- then you can -- change doors -- then change drawer fronts. Don't forget to -- Save As -- different name or you will change the original plan.
Wally Schneeberger
Kevin -- You really should try the online training. It is quite reasonable and you can learn a lot in just one month.Kevin Dunn wrote:HI Wally,
I am really new to the program so if I am overlooking something obvious just thump me on the head![]()
Kevin
Kevin Dunn
Wally,
Thank you so much. I really appreciate it.
I will definitely look into the training.
Kevin
Kevin
