Can't save job
Re: Can't save job
Scott, John,
I just tried and got the error just as John does.
Scott is running the secret error proof version of eCabinets. :D
JohnLashuay
Re: Can't save job
Post by JohnLashuay »
Thanks Kerry checking into this! Scott is running Win 7 and can't reproduce it there, but on the XP system they have they were able to reproduce it. Hopefully they will be able to get to the bottom of this.
Thanks Scott for taking the time!!!
-John
http://www.rylexonline.com
Thermwood CS 43
Scott G Vaal
Re: Can't save job
Post by Scott G Vaal »
Kerry,
Thanks for the post. I just got off the phone with John and was just able to reproduce it on an older XP machine. We will look into it and let you know what we find.
jason galbraith
Country: AUSTRALIA
Re: Can't save job
Post by jason galbraith »
This "Parasolid can't save file" issue is happening on a regular basis with me now. Sometimes changing the name of a file will help it. But more often than not it doesn't
www.eastcoastultimate.com.au
Vince Lisanti
Re: Can't save job
Post by Vince Lisanti »
I am having this issue now also. I am running Windows XP.
What was the fix?
Dell Precision M4800
32 GB RAM
NVIDIA Quadro K 2100M
Scott G Vaal
Re: Can't save job
Vince,
As noted earlier in this post, we have reproduced this on an old XP machine that we have and hope to be able to have it resolved for the next release. Try saving to a different location as this sometimes seemed to work. At this time, we do not know the underlying reason for this, but if we come up with a solution/work around before the next release, we will let you know. Sorry for the inconvenience.
Vince Lisanti
Re: Can't save job
Scott,
Are we any closer to getting this issue resolved?
This has started happening again to me on my last couple jobs and is really starting to be a problem. It seems to happen for no apparent reason. Even if saving after making no changes.
32 GB RAM
Scott G Vaal
Re: Can't save job
Vince,
It should be resolved for the next release. ...We do not have an expected time frame for the next release to offer at this time. We do not have a work around or a known way to prevent it on systems that experience this issue. Again, sorry for the inconvenience.
