Loaded a job in control nesting and when I press X or Y to nest, it gives me an error: Urecognized database format \rolling nest\Result.mdb
Help, need to cut right away....
Dave
Unrecognized database format
Dave Poulin
- Company Name: Silver Creek Cabinetry
Ryan Hochgesang
Re: Unrecognized database format
- Try loading another .twd file and nesting it, to see if the issue is with a particular .twd file or if it is with any .twd you load. Make sure you are loading the .twd file from the hard drive of cnc control and not through a network source.
- If all .twd files are causing the issue, then try the following: Shutdown THM software, go into WIN Explorer, C:\Rolling Nest, Delete: "result.mdb" file, run lates Control Nesting update, open THM and try to nest .twd file.
Dave Poulin
Did a repair on the control nesting while waiting for a reply and that works fine.
Thank you
Thank you
