Hi Guys, I'm sure most of you may have come across something like this. Sometimes I need a different set of line bore holes on the outside of a panel or even a copy of the inside holes on the outside of the panel. It is very time consuming having to choose each hole separately in order to set a depth. We need a "choose all" tab or the ability to drag a square around the edits to select them for cutting.
