Issue Adding Doors
Nat Wheatley
Issue Adding Doors
Post by Nat Wheatley »
Each time I try to add doors to this cabinet, it keeps changing the top reveal of the drawer fronts. Anyone know what's going on with this?
1.hsf
(1.17 MiB) Downloaded 310 times
Re: Issue Adding Doors
Nat,
In preferences Door/Drawer Front tab enter 0 in all your gap settings when placing doors and drawers where the openings are defined by shelves and partitions. You only need those gap settings when placing doors and drawers in the same opening with no shelves or partitions.
After you enter 0 for all gaps then delete your drawers and place them again then place your doors. All should work.
Nat Wheatley
Thanks Kerry, I'll give that a shot in the morning. -Nat
Nat Wheatley
Kerry,
That did the trick. Good to know, as I've been frustrated by that same situation a number of times in the past. Thanks again for the help.
Nat
