How would I add crown molding to this assembly?
Post by Donald Thomson »
I've attached a kitchen I'm working on and was wondering - the cabinet over the refrigerator has a side panel on each side. The cabinet is inside these side panels. I need to add crown molding around these side panels and the front of the cabinet. I was wondering if someone would be kind enough to show and explain to me how to do this operation.
Thank you!
Varno Trunidge.zip
(5.93 MiB) Downloaded 522 times
Karin Sasse
Re: How would I add crown molding to this assembly?
Post by Karin Sasse »
Hi Donald
I make my cabinets the same way, If you make your Panels out off a Cabinet with everything removed but the 2 sides, you can add the moulding to that. my inside cabinet has no moulding.
save it as an assembly and it rezises in 2 steps
Fred
Don,
I just created a cabinet that is 1" tall that has crown on it that I can re-size and wrap around different cabinets.
Fred's way is probably best for the way you are building the cabinet. You will have a cabinet that is just end panels.
Fred and Kerry,
Thank you very much for your ideas. I will incorporate and make it happen.
