Could someone please help me to find hardware,[ pulls,knobs, etc. ] to use in ecabs, since ecabs does not have source in program? Thank-You in advance,Ron
You can download pulls from our website. They are on the same page as the install/update file. Go to {member services}, {software install/updates}. scroll down a little and you should see some additional install files you can download. I recommend using the (low quality - high performance) set especially if you would have a weaker system. They look good at your typical distances and will not be as taxing on the PC.
