Is there any way to zoom in to what you are working on in the constraint manager. I'm working with 5mm holes and finding the center is proving to be tedious.
Hold down control or shift - can't remember at the moment, and you will be able to left click on the mouse and hold it on then drag a rectangle around the items you want to zoom in on.
Donald Thomson wrote:Is there any way to zoom in to what you are working on in the constraint manager. I'm working with 5mm holes and finding the center is proving to be tedious.
Just hit your + key and you can zoom forever. To go back -- you guessed it hit the - key. FWIW
