Have associated them to the cabinet,render and presentation view are OK but just dont show up in the LDE except for a small dot each end.Am I missing something ?
help with display object
Al dedenus
- Company Name: Creative Kitchens and Interior
- Country: NEW ZEALAND
Starting a simple wardrobe but the sample HSF closet rods are not showing up in the LDE
- Tibshraeny master wardrobe.esj
- (160.02 KiB) Downloaded 373 times
Re: help with display object
I get the same results as you Al. It seems all the Display Objects that I try are only showing partial lines.
Al dedenus
Have never had this problem before with wd/robe rails, guess I'll have to use a display panel or board stock so I can show it to my client with dimensions
- Scott G Vaal
Al,
I see what you are describing and I will add it to the list to be looked into. Currently it is there but only has the edges showing at each circular end.
Al dedenus
Thanks Scott, in the meantime I have used stretchers for the wd/robe rails as a work around
