Hogging away extra material in PM
Post by Forrest Chapman »
I'm wondering if any of you guys doing profile modeling have needed to remove excess material from around a deep profile. For instance I have a deep cove crown curved coming out of a over sized piece of stock. I can cut the outline out with a 3/4" bit but this still doesn't give the needed clearance for the tool chuck when using the small and short cleanup tools. I could buy a bit extender but would rather not. If we could enter the size of our stock and choose to "remove excess first" the problem would be solved.
Company Name: Halls Edge Inc
Re: Hogging away extra material in PM
Post by Josh Rayburn »
Hi Forrest,
I've had that issue a number of times. I normally use an alternate software to do the modelling so I have more control.
That would be a helpful feature, agreed.
Ray Jorgensen
Post by Ray Jorgensen »
Forest -
how about making a tool that will perform your hogging operation? Apply it first and then apply your profile. I would think you would end up with 2 regions that you can assign different tool groups.
I've done this in the pass to get small cleanup passes that the modeler wouldn't process automatically.
