Ray, I wouldn't put them on a CNC. Too much movement and unpredictability when cutting the material.
Cutting wet or green wood creates problems with the machinery and the tooling, as I'm sure you already know.
It's almost like doing a job in teak - you have to retool and oil every machine that touched the teak when the job is done, it's a real mess. Most people forget to figure that into the cost and then wonder why the sharpening bill is through the roof and then another day goes by changing all the knives in the shop......yeah I've been there.....
It really depends on how your shop is set up.
Previously, I had a shop that was actually well equipped to handle teak or wet wood, or jobs that required changeover and quick setups. I had multiple jointers and planers, also multiple shapers. Therefore, I could changeover one set of machinery - and choose the smallest jointer and/or planer etc. to work on stuff like that. Then I still had another set of machinery for flattening and thicknessing the 24" wide raised panels for the other job happening at the same time. Nobody had to walk up to a machine that was unusable. Thus I did not suffer greatly, I only had to sharpen 8" jointer knives not the 24" knives. I could choose the most economical machinery for the job and figure in the time and material it cost to sharpen and change the tooling for those specific machines. What I'm getting at is the percentage on a job basis was not the way I chose to calculate it. I even had multiple larger shops in the area throw me the teak work so they could avoid changing their moulders / S4S machinery or other tooling.
Not sure what your setup is like so it's hard to say.
Hope this helps,
Absolutely man, that's the way to go. This whole time I thought you were trying to cut wedges 3" thick on edge - but this should be a piece o' cake. Let us know how it turns out Ray.
