I was wanting to know if inside wall measurements can be seen in between walls, if you add walls to a room to know if the placement of the wall is correct. I thought there was a way to see distance from wall to wall.
Nightrider RV
1056 Pinnacle Church RD
Nebo, NC 28761
Mouse over your wall in custom Layout then look to the lower left of your screen at "Information" and you will see the Start Point.
This will give you the location.
If you have "Show custom Layout Item Detail Display" checked in Preferences this information will also display in a pop up window when you mouse over a wall.
I'm seeing that measurement I thought there was a way to get a quick measurement like when a cabinet is highlighted and a wall is touched and the distance is shown.
Nightrider RV
Nebo, NC 28761
