I tried to update my eCabs software and it crashes. Claims an unrecognized data format, doesn't throw any error codes. It loads the main screen,I see the splash screen and it freezes up.
Help
If running Vista or Win7 go to C:\ProgramData\Thermwood\eCabinet Systems\localstore
or
If running XP go to C:\Documents and Settings\All Users\Application Data\Thermwood\eCabinet Systems\localstore
Then, delete the file named localstore.mdb. Make a copy of the file LocalStore.6.0.ref, then re-name the copy of the file to localstore.mdb. Run eCabinet Systems and see if you are back up and running.
Always good to have a smart guy around. Yes that seems to have gotten eCabs to load. I notice now though that I don't seem to have the hardware that I had entered into eCabs.
Does LocalStore.mdb contain hinges drawer slides etc? MY sheetgoods, boards seem to be OK but the hardware pieces I entered in seem to be gone. I did backup my files can I try to see if a backup copy of LocalStore will work or is it another file altogether that I am missing?
Yes, the localstore.mdb hold your hardware. Just load an item or job that you know has the hardware in it and add it when it asks. Or, if you have been doing backups, you can copy that file back over. The materials are kept separately in the ecabinets.mdb.
