Ecabinet6.0 update build 8 not working
mohan kommineni
Company Name: ACRIFAB MANUFACTURING Pty Ltd
Country: AUSTRALIA
Post by mohan kommineni »
Hello all
i have downloaded the latest version and it says build 8 on the file itself (after downloading on to desktop) and when running the processes it says it is build 7 and in the next step it says build 8 and in this step the installation finishes very quickly and once clicking finish we have tried ecabinet systems it says verify and fine it opens up the software and still build 7 and checked in help about ecab soft it shows build 7also
so is the software update not working
has anyone faced this issues yet or its happening with me only
any support would be appreciated
thanks
Mohan
Rick Deskins
Company Name: Thermwood
Re: Ecabinet6.0 update build 8 not working
Post by Rick Deskins »
Can you uninstall V6 Build 8, then reinstall it and see if it works?
Rick Deskins
mohan kommineni
Country: AUSTRALIA
Rick Deskins wrote:Can you uninstall V6 Build 8, then reinstall it and see if it works?
Hello Rick
we have uninstalled the update infact on the same spot when it didnt work and after your message here in the forum we have tried to reinstall the same and the process was different and which is showing thnigs have changed and at the end the result was `it works man`.
thank you verymuch for the help
Regards
Mohan
