Question about applyed carvings
- Scott Marshburn
We have a request to do some applied carvings I downloaded the carving update for control nesting and am going to download the carving libraries do I have to install the libraries on the controller as well as ecab can I even install them in ecab (the applied carvings) I see the folder for inset carvings in ecab but not applied carvings I will post this in ecab forum also. Thanks for any help.
Daniel Vonderheide
Re: Question about applyed carvings
Scott,
You will have to install the carving files on both the machine and the computer running ecabinets. If your machine does not have the carving libraries on it already, you will have to install the carving library utility first. Go to the page listed below and click where it says "CLICK HERE FOR SETUP INFORMATION AND INSTRUCTIONS". You will then have to download and install version 3 of the carving library utility on your control. You can then install the carvings on the control. Hope this helps.
http://www.ecabinetsystems.com/ecabinet ... ograms.htm
