I need to cut a part that is right at the edges of the sheet (I can only leave 2 mm each side) and i am getting a x axis out of bounds error at machine.
I have the nest to edges option selected and a collar of 2mm, when I graph the job no error comes up, it will start cutting then stop and the
X axis error will come up. I assume it is to do with the part being at the edge of the bed but I have to keep it at that size and i cannot see any
Physical reason for it not to be able to.
