Just Wondering how to associate handle holes to a door or draw front i acidently came across it when i hit h when i high lighted a door doe you have to set up a hole pattern?
Yes, you have to create a hole pattern in the editor, select it from the pulls menu on the right and apply it with the add/locate pull menu on the left.
so in the hole pattern editor if you use the x and y axis lines as the edges of door or drawers (if this is correct i will need to do left and right handle) and then go into door and draw editor and highlight what door or drawer and associate the hole pattern to it? it would be appreciated if you could give me a step to step basis on how to apply a door handle cheers jason
The pull pattern is centered in the hole pattern editor. X0, Y0 is the center of the pull. If you search for pull pattern in the help, you will get a more detailed info on how to make the pull pattern.
