I'm trying to add drawers behind doors, and I'm not having successful results. in fact, I'm experiencing some erratic behavior, for instance, I go to the door/drawer editor, hide the doors, and select the area I want to add a drawer. sometimes it works, sometimes I can't even select the area. I'm guessing there is a much easier way to do this, and would appreciate any advice.
The other minor difficulty I'm having, is with laying applied panels to ends, backs and for use as wainscot. Rotating the object isn't working very well, sometimes I can set it to 180 or 270 degrees, other times it just refuses to allow the desired degree, and instead goes to 91 or 89 degrees instead of 90, no matter how many times I set it to 90 and lock it. and suggestions? or is this just the way it is?
thanks,
Kyle
