Error finding part in flip op array
Company Name: Halls Edge Inc
Post by Josh Rayburn »
What does this mean?
Any help appreciated!
Re: Error finding part in flip op array
Supporting files
cn572 badflip 100512.zip
(340.15 KiB) Downloaded 663 times
David Egnoski
Post by David Egnoski »
I believe I had that same error a few weeks ago. In my case I had a bad cable on my barcode scanner and the value scanned was missing a digit or two. I replaced the cable and haven't had the problem since.
I think the error indicates that the control can't find the entered flip op # in the program.
Good luck.
Dave Egnoski
Richmond Cabinet & Millwork
Hi Dave,
This happened in CN Desktop - Never made it to the controller. I can't produce the code without getting this error message.
Daniel Vonderheide
Post by Daniel Vonderheide »
Josh,
Have you tried to nest this and create the code at the machine? I can import your settings and it works fine. This makes me think that it is something corrupted like a table in your desktop version.
Daniel, no I haven't - I've been using CN Desktop exclusively for over a year now. I don't even know what version of CN is on the controller at this point.
I'll give it a go and see what happens. I've also got another PC in the office that I can try it on too.
Will report back soon..............
