pocket operation failer but cleanup suceeded
Will Williamson
any one have this problem It will create the cleanup tool path but not the pocket
Will
http://www.willmade.com
- Brad McIntosh
Re: pocket operation failer but cleanup suceeded
Will,
It depends. It may happen if, according to the calculations, the pocketed area is too small for an actual "pocketing" material removal operation - but large enough for the "Clean-Up" pass. I believe that this can be affected by the available tooling for pocketing operations, "Clean Up Amount" and possibly the "Step-Over Percentage".
Are you getting this message, yet having material remain in the middle of the pocketed area after the clean-up pass?
Will Williamson
Brad thanks if I had your email address I would send you the dxf and settings file also
this is a large pocket area maybe 2 or 3 square feet with 47 arcs and lines I have made so many setting changes I am lost, Daniel and the guys in programming are reviewing the files and settings
Will
Daniel Vonderheide
I have looked at Wills files and found the issue. THere were some arcs that were not tangent causing calculation errors. I have corrected the files and sent them back to Will.
