Machine seems to be out of level
- Scott Marshburn
Our machine seems to be out of level when we fly cut our waste board and flip it left to right the through cut scores are deeper on the 901 corner and almost 0 on the adjacent corner could someone outline the proper way to get It back to level. Thanks!
- Brad McIntosh
Re: Machine seems to be out of level
Scott,
Resurface the top of your main SPOILBOARD first. This will "level" out the work envelope. Then resurface your WASTEBOARD. Since the SPOILBOARD is now "leveling" things, your newly resurfaced WASTEBOARD should be flippable, rotateable, etc due to it's new uniform thickness. (Humidity caused variations excluded.)
Hope this helps.
Hope this helps.
- Georgi Baltov
- Company Name: Top Notch Cabinets
I resurfaced our nemi tables about two weeks ago for the same reason
Top Notch Cabinets
http://www.topnotchcabinets.com/
