Has anyone had a issue with the hardware hole editor? Today we needed to create a custom hole pattern for a drawer slide.The holes show up on the cabinet ends but not the drawer box.I am sure that I made them correct as per the help files. Negitve depth for the ends and positive debpth for the drawer. Any Help
Negative depth for the draw front as well. From what I can gather, they've changed everything to suit what's in the help book, and negative depths for both ends and draw fronts work. Old patterns work as usual, but new patterns are to be done diffrently. This is how it works for me at least ...
Jason The holes I need are for the slide on the drawer sides not the drawer front. I Tried changing the depths to negative for the drawer sides but they still do not show up.
Ok I got it to work If I want holes in the drawer sides the holes need to be in Quadrant 1 . The same as for the Cabinet ends except for a positive depth. So if the pattern is the same for the cabinet ends as the drawer side the I set the depth for the same hole to a positive and a negative.
