Just curious if theres chance that offset fixture can be adjusted on u bed in x axis i've tried every thing the graph moves but the part don't.I can adjust y axis on this bed.X bed follows what i tell it.this has got me stumped.
You may need to review the Supercontrol manual. If you are trying to move a part that normally runs on the X table to the U table you will need to establish an new Fixture Offset that contains the U & Y position (not the X &Y). After that, you call the axis redirect command (in your case G26XU). At the next index move the machine should relocate to the U table. At the end of your cut sequence on the U table, call a G27 to cancel the axis redirect before sending the machine home. It is IMPORTANT to call the offset poistion before calling the axis redirect.
Hope this helps!
Pete
Pete Riddle
Programming and Software Instructor
Thermwood Corporation
904 Old Buffaloville Rd
Dale, In
47523
