I've created a hole pattern for a Blum TandemBox slide including the 10mm front fixing holes with a 12mm positive depth. I also created a 12mm thick slab front with 0mm thick edgebanding (work around for no edgebanding) I was then planning to use these fronts as a hand drill template for the outsourced fronts I will be ordering.
I can't seem to get the 10 mm front fixing holes to show up on my drawer front. Is there something I am not doing? I have assigned a slide with associated hole pattern applied to the drawer a # of times. No luck. Help appreciated.
Integrated drawer system dwr frnt holes missing
TonyGiunta
- Company Name: ToSa Design
Daniel Odom
Re: Integrated drawer system dwr frnt holes missing
You have to add drawer fronts w/ drawer boxes and apply the slide hole pattern in the door/drawer editor, not the drawer box editor.
TonyGiunta
I created the hole pattern that I assigned to the slide and the drawer. This is in the door/dwr editor. Don't know if this matters but my default drawer box doesn't have any sides, only back and bottom as required for these type of drawers. I have not tried again today... Thanks
Daniel Odom
No, the drawer box doesn't really matter, I'd check your values for the front holes. Drawer box editor>set default box>set slide pattern>apply to cabinet>add drawer w/ box. If that doesn't work it's the pattern. There's a tutorial in the help file, you can check out one of my patterns, works well for me. I set all my holes @ Y=0 so I can adjust to different drawer box heights using the same pattern.
- blum metabox front brackets 10mm v2.txt
- (24.56 KiB) Downloaded 404 times
