Build 13---I am trying to place a window in outside wall. I can position the window, but no image will show. I tried my own images and several of the canned images, but none will show in the editor or on the wall. Same with the window trim. Any thoughts? Images work for everything else--cabs, floor, etc.
I am unable to reproduce this. Do you have the Apply Image option checked when adding the window? Also, If you have the Show Room Colors option checked on in your Custom Layout Parameters, it will not show the image unless you are in Render View. If you uncheck this option, you should then see it in the main custom layout area.
