LDE TEXT REVISION NOT WORKING
Vince Lisanti
Post by Vince Lisanti »
I am no longer able to revise text in the LDE. I am not sure if anyone else is experiencing this?
Dell Precision M4800
32 GB RAM
NVIDIA Quadro K 2100M
Scott G Vaal
Re: LDE TEXT REVISION NOT WORKING
Post by Scott G Vaal »
Vince,
If you are changing a Leader text or Note text, make sure that you are in the mode of the item you want to change. So, if you want to change a Note, click on Note mode icon at the top, then Shift+Left-Click on the note you want to change (it should turn blue when it is editable). If this does not help, I will need to know more info from you.
Vince Lisanti
I realized I was doing it wrong right after I posted this. It works just fine.
Feel free to delete this thread Scott
32 GB RAM
