I went into door/drawer editor with my cabinet to add and locate pulls. it says to add hardware before doing it by clicking the add hardware tab below. I don't see that tab. I recently loaded e cab on a new computer and I do remember the add hardware tab on the old computer. the old computer may have had an older version of e cab on it when it crashed. is this version different as far as the add tab? thanks
John
adding hardware
adding hardware
John
- Scott Marshburn
Re: adding hardware
Move your mouse curser all of the way to the right of your screen. You will see the options that you are looking for. You can click on the thumbtack icon to lock this if you wish.
Re: adding hardware
thanks, I see a list of maufacturers, but no actual pulls or knobs to select
John
- Company Name: Thermwood
Re: adding hardware
You may need to redownload and install the pull hardware.
http://www.ecabinetsystems.com/ecabinet ... pdates.htm
Rick Deskins
Re: adding hardware
where do I download this from, all I see are cabinet libraries, no hardware
John
