Door Material Color Change
John J. Desmond
Post by John J. Desmond »
I need to add a color for Doors and Drawer fronts. I can't figure out how to do it. I need gray. I added and changed the face frames to gray but I can't add a color to the doors and drawer fronts. So, is there a way? Thanks.
Scott Marshburn
Re: Door Material Color Change
Post by Scott Marshburn »
Hi ,John. If you are wanting to do this in custom layout.
1) Select the cabinet/cabinets that you want to change the texture on.
2) Right click anywhere on your screen. A dialog box will pop up with a list of options.
3) Hover over edit options and click on modify textures or hit M on your keyboard. This will bring up a window with a list of all of the textures that is used on the selected cabinets.
4) On the far left of this screen in the type column find your door/drawer fronts. If you are using Conestoga. It will be listed as Conestoga door/drawer front.
5) Select the original texture in the original texture column.
6) In the Replacement texture column click the highlighted selection. This will bring up the list of image directories.
7) Select the appropriate directorie and the image you want displayed. Click apply then ok.
Hope this helps.
If you want to change the textures in the cabinet editor. You might find this video helpful
https://www.youtube.com/watch?v=9ncqRo6 ... 0U&index=9
John J. Desmond
Thanks Scott. This helps for sure.
Scott Marshburn
Glad I could help.
Wally Schneeberger
Post by Wally Schneeberger »
I'm a little late on this but you can change a plan many times and save it as a different name and still keep the original. FWIW .
