When trying to place some of my base cabinets in this view and then move them. It seems once they are place i cannot move them anymore. I was able to select the cabinet. Then in the left side of the screen it would indicate the position on the wall. I would be able to edit the left/right/top/bottom values to fine tune cabinet placement.
Did something change in the last release of ecab.
Is anyone else having this issue.
I can made these adjustments with my upper cabinets but not base cabinets.
I tried using one of the standard base cabinets from the ecab standard lib as well with the same result.
Thanks in advance.
Custom Layout - Elevation/Wall view
Steve Detina
- Company Name: Silhouette Custom Cabinets
JR Allen
- Company Name: JRs Woodworx
Re: Custom Layout - Elevation/Wall view
Try setting the Placement Mode to Freestyle.
