Is there a convenient way to set the drawerbox behind a drawerfront a set distance from the top edge of the front, rather than the bottom? When I place a drawer in a cabinet, with the parameters for bottom and top inset, it seems to be always referenced off the bottom of the drawerbox. That is if I set those parameters with some "slop" between the actual space and the insets required it places the drawer biased towards the bottom of the opening. presumably to maximize the drawer height.
What I'd like to do is specify a top inset so that every cabinet drawerfront exposes the same amount above the drawerbox, to make adding locks to these drawers after the fact more straight forward. It seems no matter how many times I address this with clients before fabrication, there is always an after the fact conversation " can we just add a lock to that?" It would be helpful therefore to index this setting to only the top of the drawer so fitting stretchers onsite for the catch is standardized.
