THM Desktop on 10 year old machine
I've purchased THM Desktop and can't run the sync program on my Windows XP control. Anyone using this on a machine like mine? Please PM me if you can.
Thank you.
Thank you.
Dave Egnoski
Richmond Cabinet & Millwork
- Jeremy Schiffer
Re: THM Desktop on 10 year old machine
I'd like to know the answer to this as well. Been thinking about getting the desktop version to interface with our CS41.
CS-41 4x8
CS-45 5x12
CS-41 4x8
CS-45 5x12
Re: THM Desktop on 10 year old machine UPDATE
With a little help from Thermwood, we resolved the problem I was having. The desktop version has all my settings and tooling from the control.
I would still like to hear from those that have been using the desktop version for a while. Have you encountered any issues running programs created on the desktop version?
Dave Egnoski
- Josh Rayburn
Dave,
We have been running THM Desktop instead of using CN at the controller for years. It works great. No issues.
Josh
Josh
Thanks Josh. Ran my first job out of THM Desktop yesterday and no issues. It saved me a whole bunch of time.
Do you export from THM to the desktop version when tooling changes?
Dave Egnoski
- Jeremy Schiffer
My next question is, how does one go about purchasing it? It doesn't seem to be referenced anywhere on the Thermwood website that I can find.
CS-41 4x8
CS-45 5x12
CS-41 4x8
CS-45 5x12
- Clint Buechlein
You can contact Pat Dauby for pricing and information. (812)937-4476 ext 217, or email at PNDauby@thermwood.com.Jeremy Schiffer wrote:My next question is, how does one go about purchasing it? It doesn't seem to be referenced anywhere on the Thermwood website that I can find.
- Jeremy Schiffer
Thanks Clint, I've sent Pat an email.
CS-41 4x8
CS-45 5x12
CS-41 4x8
CS-45 5x12
Hi David, I don't use the sync for various reasons. What I do is make all my tooling the max size at the desktop version. IE: the 3/8" compression for the outline tool is always set at .375". It can be whatever size under that it needs to be at the controller and offsets will compensate for it. Same goes for pocketing tools. Drill bits are always consistently sized since we don't sharpen them. I've yet to run into a problem with that.
Thanks for the tip, Forrest. I'm enjoying how quickly I can nest, print and create the cnc file with the desktop version.
Dave Egnoski
It absolutely saves processing time. I have a 15 year old controller that runs code fine but gets bogged down when trying to nest large jobs. Plus you can process the next job while you're running a job. The other issue I started running into is finding printer drivers for new printers that work with windows 2000.
- Josh Rayburn
Dave,
We do the same as Forrest. I have not used CN on the controller in years. In fact the version on the controller is so old it won't even run anyway.
Josh
Josh
