THM desktop version
- Jeremy Schiffer
THM desktop version
I see that the new CN version has a feature that requires THM 10.3.6. We run the THM desktop software (version 10.0.8 Desktop Edition), can we use this link http://www.thermwood.com/updates_qcore_home.htm to update it? Or is there a different file/method to update it?
CS-41 4x8
CS-45 5x12
CS-41 4x8
CS-45 5x12
- Clint Buechlein
Re: THM desktop version
Jeremy,
To update desktop version open it and go to Control Options, then Communication, and finally Check for Updates. At the moment 10.3.6 had not been released, though we are close. The report will still work, just won't break down the times for you. The Program Time Estimate will give you an estimated time though for the entire file. That is available under Control Options, Program Timer Options, and Program Time Estimate.
I'll post back when we release 10.3.6.
- Jeremy Schiffer
Thanks Clint
CS-41 4x8
CS-45 5x12
CS-41 4x8
CS-45 5x12
- Clint Buechlein
Jeremy,
A little late, but the latest version for THM Desktop should be available for update under Control Options, Communication, and Check for Updates.
