Black screen
Black screen
Hi all used machine this morning then screen went black, turned it off then on it stayed on for a few minutes then black and came up " entering into sleep mode" then black screen,but now when i turn the machine on "No Video Input" floating about, i have replace the CMOS battery as this has sorted this out in the past but hasn't this time. has anyone come across this problem [Gen2 control].
Cheers Stephen
Cheers Stephen
- Clint Buechlein
Re: Black screen
Stephen,
Give a call into our tech services department so they can help you sort what is going on.
Re: Black screen
Hi Clint the services department in the states or AMS in the UK?Clint Buechlein wrote:Stephen,
Cheers Stephen
- Clint Buechlein
Re: Black screen
Typically there in the UK, but for something like this they will end up having to talk to us in the states. You can also email service@thermwood.com
Re: Black screen
Replace the onboard battery, on the mother board, if that doesn't work let me know I have a couple more fix's
Will
http://www.willmade.com
Re: Black screen
Hi Will that hasn't worked, what other fix's have you?Will Williamson wrote:Replace the onboard battery, on the mother board, if that doesn't work let me know I have a couple more fix's
Cheers Stephen
Re: Black screen
Did you push the small black button next to the battery to reset the bios?
Take the memory sticks out and spray the contacts with electrical contact cleaner and put them back in and pull then out a couple of times
that worked great for me last time
Will
Re: Black screen
Hi Will i have pressed the button we have 2 together on our motherboard! i'll give the memory sticks ago.
Cheers Stephen
Cheers Stephen
Re: Black screen
Hi Will that hasn't worked have you any other suggestions?
Cheers Stephen
Cheers Stephen
- Jeremy Schiffer
Re: Black screen
Unlplug the monitor from the video card, remove and reinsert the video card, and plug the monitor back in.
CS-41 4x8
CS-45 5x12
CS-41 4x8
CS-45 5x12
Re: Black screen
with the side open plug another monitor in and try it
Will
- Jeremy Schiffer
Re: Black screen
With an open hand, whack the side of the controller several times. Won't necessarily fix anything, but sometimes it makes me feel better.
CS-41 4x8
CS-45 5x12
CS-41 4x8
CS-45 5x12
Re: Black screen
I battled that problem, for 2 years and pulling the memory chips in and out finally solved it.
Will
Re: Black screen
One more thing, check the voltage of the battery, you installed, if it is over 3.3 or under 3 you need to try another battery
I bought some ikea batteries and they were over 3.3 volts and they would not work.
So i installed them in a small flash lite and ran them down a little and they worked
More than likely in my case it was the bad memory connection all along, because since I cleaned them,
I have had no problem, been a few month now, My machine is a is a 2005 CS 45
Also clean all connections, to the mother board and the hard drive with contact cleaner
It was recommended, that I replace the mother board, on several occasions
Since this issue my tech said that when trouble shooting mother boards
Pull all the cards out video, modem, ext. and leave 1 stick of memory in just the bare minimum to run
then start plugging things back in one at a time, cleaning connections as you go
Good Luck
Good Luck
Will
Re: Black screen
Hi all it was the power supply
