I guess in all my time using eCabs I've never needed to put a cathedral or curved top door into a kitchen. Well now I'd like to and I don't see any easy way to do it. Is there no option in the door area to have a curved top panel in a rectangular door?
Hi Leo. Are you wanting a five piece door or a Mdf door? For five piece doors, in the door designer. select Conestoga then standard. The CRP 30 is an arch and the CRP 20 is a cathedral. If you are going to build them in-house you can set up the specs in the details for cut list. Alternatively you can select Thermwood as the source and choose the arch or cathedral door in there.
Thanks Scott. It's just presentation and I'll be building them in the shop. No need to tell the program how I'm doing it as I just need the render to show the client. I guess I'll search through the Conestoga list a little better. I ended up just doing them in the MDF area because I could get the look I wanted.
I knew it had to be in there somewhere. I've just never needed to use it and couldn't find much with the search other than the door designer and all I wanted to do was plop a arch top door on my cabinet.
