It reproduces for me.
Start from batch window.
Add a set of drawers.
Take to Cabinet editor.
right click , select phantom parts.
In Cabinet parts select top line .
hold down shift, select bottom line.
click select selected to phantom.
Then at the top, Select Drawer box parts.
Again, select top to bottom line and select all to phantom.
Then, select drawer bases individually and un-phantom. (so only the drawer bases are visable)
Return to main.
return to batch.
Try to nest.
I get the error message, nothing to nest or no error message but only one piece will be in the nest.
In the attached units only one drawer base shows up for me in the nest.
I get the same thing with other drawers.
Ps And if you can work out why the screw holes RTA go missing (there should be screw holes in the drawer bases) I will buy you a carton of beer.
