Adding shelf pin holes
Post by Donald Thomson »
I am designing a spice rack pull out for upper cabinets. I'd like to add shelf pins to this pull out. Is there any easy way to add 5mm shelf pins on a 1" on center spacing to this?
5-8 Aplply small-narrow spice rack dbx.hsf
(250.02 KiB) Downloaded 713 times
Ian Richardson
Company Name: Millworx
Re: Adding shelf pin holes
Post by Ian Richardson »
Instead of developing it as a dbx. Do it as a cabinet, that way you can add adj shelves with holes. Thats what i have done in the past
Thanks Ian. I went thru the painful process of part editor and constraint manager to create the holes. It was painful, but I got er done...
Ian Richardson
Or draw the holes using autocad and apply using part editor
Donald,
I agree with Ian, we build them as cabinets so you can change length, width, height, anything, then add them as a batch item to the job.
We rarely build one unless there is some oddball size or something. There are too many parts and are tedious to build in the shop so we found out it was best to order the spice shelf, mark it up and stick it in the cabinet. The shop made pullouts really don't seem make you any money.
Here is a look at what we build. I have the CNC cut pockets underneath the adjustable shelves to drop over a spoon type shelf pin so the shelves don't slide around.
