Suggestion
Company Name: Halls Edge Inc
Re: Suggestion
Post by Josh Rayburn »
Hi Donald,
Your cabinet has a phantom left end.
I don't know how it got there, but it's a doozie. Hopefully Scott will take a look and might have some insight - but I'm sure he'll ask you how you got a cabinet to this state, if you can recreate the steps to reproduce this error.
I found the phantom by CS - uncheck left end, OK, then it shows a phantom part in yellow "image not found" that can be selected, but not removed.
I'm sure this does not help, but you may have to rebuild the cabinet from a fresh start and see if you can avoid this happening....
Re: Suggestion
OK I got it.
Try the attached cabinet. Still don't know how the extra left end got there but I got rid of it and put in the stretchers.
I also changed your top stretchers to fixed shelves only because it was easier than constraining the stretcher.
Hope this helps,
Upper%20bookcase%20cabinet.hsf
(652.02 KiB) Downloaded 495 times
Re: Suggestion
Post by Donald Thomson »
Thanks Josh!!!
That is really weird how that phantom side got on there. I also noticed that somehow on the right side, the bottom and middle shelf were sticking through the right side even though those fixed shelves were set up with 1/4" deep dados. Sometimes computers just have their own way of doing things..... :?
Re: Suggestion
Yeah, this would be a really great sample to have Thermwood look into - I'm anxious to hear if they can identify how the issue could be resolved.
All the best,
Re: Suggestion
John Lashuay had this same problem quite a while back reported in This Thread
They must not have it fixed yet.
